rungel
Jan 27, 2016Tutor
Avast says my WNDR3800 has NON-2015-0211 issue
Is this something i need to fix? I have firmware v 1.0.0.48 installed. And i do use readyshare for a laser printer. thank you
- Feb 01, 2016
I think I'll probably do this http://www.dd-wrt.com/wiki/index.php/Netgear_WNDR3800
But I'm looking at the AC1900 Nighthawk also
rungel
Jan 27, 2016Tutor
Hi ElaineM,
I did have that version installed, but went ahead and flash it again. But Avast still tells me the same issue is there.
mediatrek
Jan 27, 2016Virtuoso
Per Netgear's EOL (end of life) product policy, they will have long since stopped support for the WNDR3800 with anymore firmware updates; even if there are security holes in the firmware. Basically you have to go out and buy a newer model router. Netgear will not be fixing it. The end.
- adelacFeb 01, 2016Aspirant
I hope this is not the end...
I'm in the same position : firmware uptodate and NON-2015-0211 issue.
Please NetGear : consider working on a firmware update fixing this issue.
- rungelFeb 01, 2016Tutor
