PXRG
Aug 11, 2015Tutor
Blinking power light - but not all te time
I have the (apprently quite common) problem of a blinking power light on my R6300 router. Manual and forums say this could be a firmware problem or a problem with the power supply to the router.
My issue is that it does not happen all of the time. If I cycle power on the router (which I rarely do - but have just done while I was away on holiday) one of three things happens:
1. Everything works fine so far as I can tell - internet OK, LAN OK, media server OK, USB storage access OK, can login via browser and see/alter settings.
2. Partly works. LEDs look normal during start-up, LAN works, internet available on all attached devices via wire and WiFi but: no access to USB attached storage, no media server and the config page comes up as unavailable if I try to connect via a browser (using routerlogin.net or .com or the router IP in either chrome or IE).
3. Does not work at all. Green flashing power LED, no internet on any device, no LAN so far as I can tell [I have not tried pinging the router when in this state and can't now without switching it off - I am currently in condition 2]
Number 3 is most likely, then probably 2 and then 1. It seems more likely to work if it has been off for a while rather than a quick power cycle but mostly seems random. Once up and running it seems stable working for weeks at a time without problems.
I have not tried reloading firmware nor finding an alternative power supply (none of the ones in my house are 12v 5A compatible ...)
Any ideas on whether I am likely to have a firmware or hardware problem or is this a known issue?
Thanks in advance.
I've had the same issue on a 6300. I was lucky and managed to reload the firmware, and was was back to normal in no time. I would reload the firmware while you can..
- netwrksMaster
- PXRGTutor
Thanks for the advice. I pushed the latest fimware for V1 onto the router and it appears so far to have done the trick. Even have a couple of new features!
- DaenerysLuminary
Hi,
Glad to know that the power light blinking issue is now fixed. I hope that you will not encounter the same problem again. To prevent this from happening again, always have the router plugged in to a power socket directly and have it updated once Netgear releases new firmware.
Have a great day!
- DaenerysLuminary
It seems firmware issue to me but I also recommend to try different power supply for further isolation. What version are you using by the way? If it is version 1, make sure to update it to the latest firmware version.
- PXRGTutor
I am not sure whether I have V1 or V2. The model number on the router does not include a version and I cannot get into the configuration utility to see whether that says! I huess I have a V1.
- VE6CGXMaster
When the light is blinking, can you ping the router via it's ip address? If you can what is the TTL value?
- PXRGTutor
Sorry to be slow - have been offline for a few days
Yes I can ping the router on its IP address the TTL is 100 with a connection via a wireless access point (a reconfigured older router that I use to extend WiFi coverage) and powerline adapters. I have not tried it with a direct cable connection.
- PXRGTutor
On the TTL question. I thought that ping started with a TTL of 255 (usually). 100 implies a huge number of routers between me and my local router - does the netgear stuff use the TTL as a diagnostic code when it is in failure?
