scoale
Feb 23, 2017Aspirant
C6300 router, would like to add wnr2000 as a repeater.
I can't find on the menus how to add the netgear wnr2000 as a repeater, is it possible?
Welcome to the community, scoale
Your devices should have a feature that's called "Wireless Repeating".
If you do not have that option, there's no way to do it. The only way to extend the signal is to use a cable between these 2 devices.
- scoaleAspirantThank you. That feature is not on my router.
- William10aMaster
Here is the manual for the wnr2000v1 http://www.downloads.netgear.com/files/GDC/WNR2000V1/WNR2000_SM_07May08.pdf I hope helps,
- ElaineMNETGEAR Employee Retired
In addition, both devices must have that feature.
