ROBBO1972's avatar
ROBBO1972
Initiate
Dec 26, 2017
Can not upload chk file
Hello
Can any one help ? Having trouble  latest upgrading firmware, will not let me upload because it is a chk file, tried to do it on web page where it says check, but no yes button to start upgrade,
Any help would be great
    • antinode's avatar
      antinode
      Guru
      > OK fixed problem needed to unzip file first
         I trust that you understand why saying that you have a problem with
      "a chk file" might not lead to a suggestion that you extract the
      contents of an unmentioned zip archive.
    • michaelkenward's avatar
      michaelkenward
      Which firmware is this?
      Netgear has done a rapid update for the D6400. Just days after upgrading mine I found a new version, V1.0.0.70.
      66 landed on 14 December, 70 arrived 10 days later!
      66 must have been a dud.
      PS Thanks for passing on the solution. This is a common issue, so your Solved answer might help someone in the same boat who turns up here seeking help.
