Melsmeeusen's avatar
Melsmeeusen
can you still use WEP key?
Hello people,
I was wondering if it is still possible to use a WEP key. I want to go online with my nintendo DSI for the fun, but you need to have a WEP key, otherwise it can't get on your WIFI-router. So I looked at the routerlogin, but wasn't able to find a WEP key or make one.
So is it still possible or can't I go online anymore...?:'(
p.s.
They couldn't find my model. It's a WNDR3700v3 from Netgear.
  • Retired_Member's avatar
    Retired_Member
    Jun 01, 2016
    choose 54 as mode then it should be listed
    then setup guest using WEP and main using WPA2 or WPA  The link rate will be 54 on both
  • Of course if router has a setting for that.. Better than no security at all, LOL!
    • Melsmeeusen's avatar
      Melsmeeusen
      And do you maybe know where I could find this setting? because right now I can only choose between:
      - none
      - WPA-PSK (TKIP)
      - WPA2-PSK [AES]
      - WPA-PSL [TKIP] + WPA2-PSK [AES]
      Is there maybe a setting I need to turn on first, before I can use WEP?
      And would it also be possible to have a WPA and WEP key password at the same time?
      I could also take off the password, but yeah, I'd like to have some kind of protection! haha
        Retired_Member
