sanja_nvkz's avatar
sanja_nvkz
Follower
Jan 20, 2018
Cancel password reset request
 Hello community,
I tried to reset the router password but remembered it afterwards. Now I'm still able to login to my router at http://routerlogin.net/ but when I try to login by entering the IP Address I'm asked for serial number and security questions. Unfortunately I can't remember the answers for them.
So is it possible to change the security questions or cancel the password reset request?
Thanks in advance
Aleks
  • Hi sanja_nvkz,
    1. Please try using another browser or device to login.
    2. If the issue persists, you can try doing a factory reset.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi sanja_nvkz,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi sanja_nvkz,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
