davenicsnr's avatar
davenicsnr
cannot connect second extender ac750 to network
Tried to connect with simple wps set up but failed.
So followed previous extender connection instructions and used ethernet cable between extender & laptop.
First effort failed part way through process - network security key not recognised.
So did a factory reset and started again. Gave extender new ssid for 2.4 & 5 Ghz band and completed setup
This time all seemed to go well but when connecting extender close  to the router to test connectivity same problem - no connection with wps? The router and wifi connection is working fine.
So did another factory reset to try again but this time no access to new extender set up gene?
Figured if I cleared everything I'd done out of memory and started again I might have some success.
Is there data that needs to be cleared out elsewhere?
Can someone advise how I get back into the gene.
  • plemans's avatar
    Feb 12, 2021
    If you didn't reset the original it should connect. But you can always try rerunning setup on it
  • plemans's avatar
    You're setting up a 2nd one?
    Did you shut off the 1st one during setup?
    What router are you connecting it to?
    • davenicsnr's avatar
      davenicsnr
      Yes setting up a second extender. N300 already installed on 1st floor
      No I didnt shut N300 down
      Vodafone broadband wifi hub model THG3000
      • plemans's avatar
        try shutting off the 1st one while doing setup on the 2nd. Then once its setup, power the first back on
