jhpackard
Jun 25, 2017Aspirant
Cannot connect to router WNDR3400v2/N600
- ASUS laptop
- Win 7
- Latest router firmware
I suddenly cannot connect wirelessly to the router. This followed a rerouting of power cords. The router failed to power up. After letting it sit without power, I was able to power it up and connect to the ethernet ports but not connect wirelessly.
You can try and do a hard reset by pressing the pinhole with a paper clip for 30 seconds and re-doing your configuration. Also try a different power adapter if its having a power issue.
- wcalifas831Prodigy
- jhpackardAspirant
wcalifas831 - The hard reset and reconfiguration fixed the problem. Obliged!
