kiwi1342's avatar
kiwi1342
Can't connect/flash WNDR4500 after power outage
Hi all,
due to a power outage my router stoped working. I had all orange leds. I followed this guide
http://kb.netgear.com/app/answers/detail/a_id/22688
but I can't connect to the router to update the firmware.
I did the 30-30-30 steps before attempting the flash. I can't ping the router. I also tried a different cable but no luck. I've also viewed this topic
https://community.netgear.com/t5/Wireless-N-Routers/Manually-updating-firmware-asked-often-but-threads-closed/td-p/1100543
but I am using the correct ipd, gateway.
What should I try to connect to the router?
thx
  • Thanks ElaineM. I've already tried that with no luck. I guess I have to buy a new router. Unfortunately I think I won't go with another netgear since Im seeing too many threads about hard resets after power outage. In my area they are quite frequentely :(
  • You didn't say on which version you are right now. Also, a 30-30-30 procedure has no effect on ARM routers. Further, your topic says R7000 while you list WNDR4500 as model. Which one is it?
    • kiwi1342's avatar
      kiwi1342
      hi,
      well I have no idea about the post title. I wrote "problem in flashing wdr4500". I really have no idea how it changed (I'll see if I can edit it). I have no idea about the current firmware version :(
      • ElaineM's avatar
        ElaineM
        NETGEAR Employee Retired
        kiwi1342 Try to see if you can ping by assigning a static IP address on your computer.
        Since you have factory reset the router, try to assign 192.168.1.5 on your computer. Do this on a computer that's wired directly to the router.
        Once done, see if you can still ping the router. If not, it's time to get a new router.
