Jswab
Dec 29, 2022Aspirant
Can't log into router page despite using correct login info
Hello,
I don't know the model number for my Netgear, but I am trying to log into the router page to port forward. I downloaded the Nightshark app, and even that is telling me my login info is wrong. I'm really freaking confused here because I have verified in MULTIPLE places the password is correct.
Without that there's not much that anyone can suggest.
Look at the label on the bottom.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.- JswabAspirant
michaelkenward I see the serial number and mac number, but nothing about model.
Are you sure that Netgear made it?
Unless someone has removed it, everything comes off the off the production line with a label that clearly states the modem number.
That or it is something that Netgear made for an Internet service provider, in which case Netgear doesn't support it and there is no guarantee that apps and firmware will work on the device.
