MargoD's avatar
MargoD
Tutor
Jun 08, 2018
Can't login to R6220 router after firmware update 10 days ago
I installed a firmware update about 10 days ago for my router, and now it won't let me login. I understand I need to do a factory reset, but how do I do that if I can't log in to my router? Concerned about the hacking vulnerabilities & want to change my password, etc.
  • MargoD's avatar
    MargoD
    Jun 09, 2018
    I was able to do a factory reset using the reset button in the back, and now I'm all set. Thanks anyway!
  • > [...] it won't let me login.
       What happens when you try?  "won't let me" is not a useful problem
    description.  It does not say what you did.  It does not say what
    happened when you did it.  As usual, showing actual actions with their
    actual results (error messages, LED indicators, ...) can be more helpful
    than vague descriptions or interpretations.
    > [...] I understand I need to do a factory reset,
       Perhaps.
    > [...] but how do I do that if I can't log in to my router?
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Look for "Factory Default
    Settings".
    • MargoD's avatar
      MargoD
      Tutor
      If I try logging in through the Genie, entering "admin" as user and "password" as password (which I know I left as the default), I get a message that says "Login failed.Please check the password." If I try to log in through http://www.routerlogin.net, I get a new screen that says 401 Unauthorized
      Access to this resource is denied, your client has not supplied the correct authentication.
      • antinode's avatar
        antinode
        Guru
        > If I try logging in through the Genie, [...]
           Which "the Genie"?  Ever helpful, Netgear uses the name "Genie"
        for more than one thing.  Netgear routers have a web-browser interface
        called "Genie", and Netgear offers application programs for various
        computers/pads/phones, which are also called "Genie".
        > [...] If I try to log in through http://www.routerlogin.net, I get a
        > new screen that says 401 Unauthorized [...]
           Did you again try "admin" and "password", or did your web browser
        fill in the credentials for you, or what?
        > > [...] I understand I need to do a factory reset, [...]
           Did you?
  • Okay I have faced a similar issue, I tried the factory reset , the router reset but after that even after setting the PC to static IP ( 192.168.1.10) the gateway ( 192.168.1.0 ) was not being able to be pinged by a Wired Ethernet connection.
    I registered a case and called Netgear India Support , they first again asked me to ping the static Ip gateway , but as I was not getting a response they suggested a RMA.
    THAT SHOULD HAVE SOLVED MY PROBLEM , but then the real hassle started they said they are using a new backend Tool , recently and due to which they can't process my RMA , that was 4 days ago.
    I spoke to the supervisor Mr Arthur De Cruz , he too was unable to help.
    Then today I again called them and they have still not been able to resolve their issue...and now the Supervisor was unable to talk even after 15 min hold.
    I wonder what the real issue is.?
