rockjamd's avatar
rockjamd
channel bonding c3000
Hello,
THis is in regards to Netgear C3000 wireless modem
I have had slow connectivity for couple days through comcast. I am wondering if it has to do with channel bonding. I checked wires, did a reboot, did a factory reset. When I looked at settings I noticed only one channel was locked is there a fix to this or what would my next step be before I go towards troubleshooting cable and possibly having to have a comcast tech come out.
Thank you for your help.
below are my current data
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM2569705000000 Hz-22.9 dBmV26.8 dB9779432524181
2Not LockedUnknown7693000000 Hz0.0 dBmV0.0 dB00
3Not LockedUnknown10711000000 Hz0.0 dBmV0.0 dB00
4Not LockedUnknown12723000000 Hz0.0 dBmV0.0 dB00
5Not LockedUnknown13729000000 Hz0.0 dBmV0.0 dB00
6Not LockedUnknown14735000000 Hz0.0 dBmV0.0 dB00
7Not LockedUnknown15741000000 Hz0.0 dBmV0.0 dB00
8Not LockedUnknown16747000000 Hz0.0 dBmV0.0 dB00
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA575120 Ksym/sec36400000 Hz53.5 dBmV
2LockedATDMA585120 Ksym/sec29500000 Hz52 dBmV
3LockedATDMA595120 Ksym/sec22600000 Hz50.5 dBmV
4LockedATDMA605120 Ksym/sec15700000 Hz51.8 dBmV
  • Retired_Member's avatar
    Retired_Member
    May 05, 2016
    -22.9 is a problem, I would suspect water in a splitter or connector on the outside or a bad house amp. You need to call Comcast for a service call.
    Retired_Member
    • rockjamd's avatar
      rockjamd
      THanks for your help today I am getting better speeds do you think it is still a splitter or hardware problem? Last night I was only getting 5mbps and has been slow for couple days if it gets slow again I will call comcast.  I am paying for 75 mbps
      NetGear C3000
      Date Download Upload IP Address
       5/5/2016 10:53 AM66.99 Mbps12.23 Mbps
       5/5/2016 10:52 AM66.44 Mbps11.99 Mbps
       5/5/2016 10:51 AM31.38 Mbps12.14 Mbps
       5/5/2016 10:50 AM14.68 Mbps12.04 Mbps
       5/5/2016 10:44 AM66.56 Mbps12.14 Mbps
      getting more channels this morning: NetGear C3000
      1LockedQAM2569705000000 Hz-21.2 dBmV28.5 dB22685919029606850
      2LockedQAM2562663000000 Hz-13.3 dBmV31.4 dB935504176901
      3Not LockedUnknown3669000000 Hz0.0 dBmV0.0 dB00
      4Not LockedUnknown4675000000 Hz0.0 dBmV0.0 dB00
      5Lockedunknown5681000000 Hz-13.2 dBmV23.8 dB24201039
      6Not LockedUnknown8699000000 Hz0.0 dBmV0.0 dB00
      7Not LockedUnknown10711000000 Hz0.0 dBmV0.0 dB00
      8Not LockedUnknown11717000000 Hz0.0 dBmV0.0 dB00
      1LockedATDMA575120 Ksym/sec36400000 Hz54 dBmV
      2LockedATDMA585120 Ksym/sec29500000 Hz51.7 dBmV
      3LockedATDMA595120 Ksym/sec22600000 Hz50.7 dBmV
      4LockedATDMA605120 Ksym/sec15700000 Hz52.5 dBmV
        Retired_Member
        Call before it goes out completely and they tell you the earliest app is 3 days out. The test results don't mean squat they are a snapshot in time nothing else.
        The signal levels show a problem deal with the problem.
    • rockjamd's avatar
      rockjamd
      comcst contractor came today. I found out they were here working on someone else last week and whatever they did to fix other apartment messed everyone else up. He said someone is comeing withing 48 hours to fix the main line coming in. Anyways all I can do is show this pic this is how the last tech left box on my apartment building one week ago. I have no idea what this is but he said it was messed up. This pic is how last tech left box....
      So you were right to call comcast fast.
      Thanks For help
