getreal
Oct 15, 2017Aspirant
Chromebox access to router USB AC1750 not mount
No selection for my router it's an AC1750 not AC1450
Chromebox works fine on internet, setup on ethernet.
I have several chromebox's I use for TV connect.
I have a thumb drive in each with numorus .html pages, a menu system with
canned links and searches.
Rather then have one on each box, one on router would be easier to update.
Same problem others seem to have on here. I downloaded the windows file share for chrome from google.
What file system is the router? SMB work? What do I type for share?
readyshare doesn't work. Is there a manual means to connect to the ready share drive like an IP? how would it be typed?
Works with an old windows 8 box, no updates in two years since I removed it from the INet.
Either I can't find the proper SMB Path or netgear readyshare doesn't work with chromebox.
Tried a ASUS and an HP chromebox.
Chromebox & book are the wave of the future for the connected home. Seems Netgear would get with google and solve this.
Links for those with the same problem.
- getrealAspirant
It is model R6400.
Using Chromebox with Network File Shares for Chrome OS installed from Google.
found first problem IP. Now it tries to mount.
smb://192.168.1.0/readyshare/USB_Storage
\\192.168.1.0\readyshare\USB_Storage
Will now try to mount, after a minute it says mount failed.
At least it is trying.
Is there anything wrong with these two logins
Which password does it need to work?
Tried Chromebox login, Admin, whats written on router, etc.
Found this, says it should work! So much conflicting info on subject.
https://www.guidingtech.com/59492/mount-network-drive-chromebook/
- DexterJBNETGEAR Moderator
Hi getreal,
1. What is the firmware version of the router?
2. The ReadySHARE feature was tested to only work with Windows and Mac for SMB.
3. Have you tried using your Windows or Mac computer to check if the ReadySHARE feature works?
4. Does FTP or HTTP access work with the Chromebox?
Dexter
Community Team
Whatever the problem was, I doubt that "192.168.1.0" is the solution.
The all-zeros (".0") and all-ones (".255") addresses are broadcast
addresses -- not what you want to use. The router's default address is
more likely to be 192.168.1.1.
- getrealAspirant
