gvasick's avatar
gvasick
Configuring R6300 as an access point after firmware upgrade
Hi,
I installed a firmware update this morning on my R6300 router (I am not sure how to tell if I have a v1 or v2 model):
Firmware Version
V1.0.2.80_1.0.59
After the update, there is no longer a Wireless AP option under the advanced setup menu.  How do I configure my router as an access point with the new firmware?
Thanks,
George
  • gvasick's avatar
    gvasick
    Jun 12, 2017
    That is it.  The access point configuration is under "Use other operation mode" at the bottom of the screen shot.
    Thanks,
    George
  • On the bottom of the router you will find a label with a the model number if follow by a v2 or other version that the version of the model you have.
    R6300 without a version number is a version 1, if you have say R6300v2 you have a R6300 version 2, and so on depening on how many versions for that model.
    • gvasick's avatar
      gvasick
      Thanks for the tip.  Mine is a version 1.
      I could still use some help with configuring it as an access point after the firmware update.
      Thanks,
      George
