alani's avatar
alani
connection problem
I cannot establise internet connection Power LED and WiFi Led are soild green .Internet light is off
  • plemans's avatar
    What modem/gateway are you using?
    The WAC124 is by default an Access point and comes in access point mode. meaning it doesn't have a dhcp server running. You can switch it so it'll function as a router but it needs to be done through the settings. Page 23 and 163 are beneficial to changing modes on this.
    Find the manual here:
    https://www.netgear.com/support/product/WAC124
  • Thank you for your prompt response, I appreciate your help in advance. my device is Fiber  Modum and router together but does not cover all rooms so I need to have a separate router to enhance my  network the problem is the internet connection is not established  as follows
    1. when I switch the power is on the Power LED lights solid green
    2. The WiFi LED lights solid green
    3. The internet LED Does not switch on and it means the internet connection is not established
