dkgoodwin00
Dec 10, 2021Tutor
constant site cannot be displayed msgs
AC1750 on Win 10 - ran most recent firmware update. Since then I am constantly getting site cannot be displayed msgs. It is across Chrome, Firefox, Brave. I have to reload page 3,4,5 times and finally the site will display.
Wired connection or wifi. Is there an issue with the latest update?
My work requires me to be able to research and give complete answer quickly. So more than 3 minutes each try to launch a website not good.
Anyone else experiencing?
what actual router do you have? AC1750 is a speed
What firmware version did you install?
What modem/gateway is it connected to?
Have you tried enabling ipv6 and rebooting the router?
If you've tried that, then try downgrading the firmware a version. Some product lines have been running into dns issues on the newer firmware.
Thank you for responding, I really appreciate it.
modem: arris surfboard 6190
Netgear R6400v2
current Firmware: V1.0.4.120_10.0.91
5gz and 2.4 both set up. Pushing 5gz as defaultNot a strong hardware person, so have not tried ipv6 fix. Not real sure how I go about it. Looking.
Might have to roll back, I had not upgraded for a bit so though I best do it.
DKG
I see IPv6 and what setting is recommended? Auto config?
