Tall-Eric's avatar
Oct 30, 2016
Corrupt firmware, tried reset, can't ping router (WNDR4500/N900)
We had a power outage at our home, after that the N900/WNDR4500 router power light started blinking green which indicates there is a firmware issue. Reseting the router didn't correct, connection to modem shows solid amber indicating it can't connect (same cable works fine for a PC), and I can't ping nor otherwise connect to the router @ either 192.168.1.1 nor 192.168.0.1.
I'm presuming the router is toast/bricked at this point, unless someone here has some alternate suggestions to offer?
Thanks in advance for any help anyone can offer...
