FamilyCanyon's avatar
Jun 03, 2016
Delete a Netgear ReadyCLOUD Account
I want to completely delete a Netgear ReadyCLOUD portal account I created. Does anyone know how I can do this?
  • Vasily We do not delete accounts.
    You may create another account or use the same old ReadyNAS remote account that you have migrated to MyNETGEAR.
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello FamilyCanyon,
    Did you already update to myNetgear account?
    I believe you may need to contact support as this account is linked to devices that you have registered with Netgear.
    • Hey Jenn,
      Yes, I have upgraded my ReadyCLOUD account with MyNetgear. I would have thought an option to delete one's account would be in their profile settings, but there isn't. I attempted to contact support via e-mail or phone, but I could only find support help through the Netgear Community or Knowledge Database. I didn't see where Netgear would give me any other choices since my router is outside the 90 support window.
      FamilyCanyon
