papantonis
Jan 06, 2022Aspirant
DGN2200 router limits attached devices to 15
I am using the DGN2200 router for the last 15 years without any major problem.
The problem I'm facing
Recently, I bought several smart devices to build up a smart home and realized the the router limits the number of attached devices to 15. The next device trying to connect to the router get an error and wouldn't connect(I have tried this with several different devices).
I know that it's an old router, but since this doesn't have any other problems, I thought that there must be a way to overcome this (according to docs that I found online, it should support by default at least 32 devices connected simultaneously).
Things that I have tried
1) Modify the Wifi channel (tried 1,6,11 since it's a 2.4Ghz router)
2) Upgrade firmware
3) Several reboots
Related threads
I have looked thourougly in the community and I found the threads #1 and #2 and #3 (they are related to newer versions of this router but I suppose that they all have the same problem). In all of these threads, either no solution was found or they were asked to contact the support (which I was not given the option to do since it's a not-supported product).
Any suggestions really appreciated
Router model: DGN2200
Firmware version: V1.0.0.60_7.0.57
- You might try a factory reset. If this doesn't help any then it maybe time to retire this older modem and find something anew, or bridge the modem do that the rouer and wifi portions are disabled, continue to use the modem and install a newer generation Wifi router or wifi MESH system. - Netgear has set up a community forum specifically for the DSL Modem products. Might be more likely to find someone who has a solution if the question is posted there:
 https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
 Thank you.
- FURRYe38Guru - Experienced UserYou might try a factory reset. If this doesn't help any then it maybe time to retire this older modem and find something anew, or bridge the modem do that the rouer and wifi portions are disabled, continue to use the modem and install a newer generation Wifi router or wifi MESH system. Netgear has set up a community forum specifically for the DSL Modem products. Might be more likely to find someone who has a solution if the question is posted there:
 Thank you.
- plemansGuru - Experienced UserLooks like that device was released in 2011. so its getting a big long in the tooth and was a pretty base model device at the time it was released. It might be time to look into upgrading both for performance and security benefits. It *should* support more devices than that but on a device that old, even if it could, I'm doubtful they'd function very well. and you're right in it being end of life. are you using dsl for it?
- papantonisAspirant- FURRYe38Guru - Experienced User👍 - michaelkenwardGuru - Experienced User... thus taking us down the road to chaos. Forgive me if I ignore this conversation.
