FinnB's avatar
FinnB
Does buying a modem affect the need of a Netgear nighthawk router
Hey,
I’m buying a Netgear modem and I currently have a nighthawk router. The main reason I got into all this is because my home WiFi is under too much pressure from other devices so I can’t game without serious lag with it hence why I’m now using a Netgear router. I have a PS4 and my main question is can I plug a lan cable from the modem into my PS4 without the router or is the router still a necessity.
  • > I'm buying a Netgear modem and I currently have a nighthawk router.
       Actual model numbers would be more helpful than ambiguous/vague
    descriptions.
    > [...] can I plug a lan cable from the modem into my PS4 without the
       Generally, you can connect at most one device direvtly to a modem,
    either an actual client device or a NAT router.  "other devices"
    suggests that you wouldn't be satisfied with one client device.
    descriptions.
    • FinnB's avatar
      FinnB
      Thank you that helps a lot. The reason I didn’t go into detail on what modem I was buying and what router is because I didn’t think it mattered for this question as I was just wondering whether or not you can plug a lan cable from a PS4 to a modem.
      Thanks
  • michaelkenward's avatar
    michaelkenward
    Your footer says D6100. If you own one of those it is a modem-router that may or may not work with another modem.
    • antinode's avatar
      antinode
      Guru
      > My setup is basically a PS4 pro and a nighthawk router and my home
      > WiFi but that's not the WiFi I use for my PS4. [...]
      >  My home WiFi just uses the router provided by my provider.
         Not a useful description of anything.
      > [...] then I'm going to set it all up properly
         Perhaps, but so far, the more you explain, the less sense it all
      makes.  It might help if you would provide a list of your equipment
      (current and planned), and an accurate description of what is connected
      to what.
