zips-fpv
Jul 07, 2017Follower
Emailing logs...
Has there been a resolution when it comes to emailing logs from this router, R6250? I have dug and dug and I cannot find anything specific to mine. Any information I found was 5+ years old, or is abo...
- Jul 12, 2017
Hi zips-fpv,
Are you using a Gmail account? If yes, the steps below may help out.
1. Log in to your Gmail then go to Settings.
2. Click on Accounts and Import then click Other Google Account settings.
3. Go to Security Check-up.
4. Click on Disable access on less secure apps.
5. Select the radio button to turn ON Access to less secure apps.
6. To test if it will send the logs via email, go to the router logs option on the router's GUI then click on Send Log.
7. You should now receive the router logs.Regards,
Dexter
Community Team
