dsherry's avatar
dsherry
Guide
Oct 28, 2015
error message with log emails
hi,
I am getting this error message after having tried to set up e-mailing of the log file for my router
[email failed] SMTPclient: smtp.mail.yahoo.com: unknown host
On the e-mail page in Netgear Smart Wizard, I have set things up as follows
Your Outgoing Mail Server           smtp.mail.yahoo.com
Send to This E-mail Address        *********@yahoo.com  (my email address)
User Name                                    *********@yahoo.com
Password                                      ############  (my password)
Could someone kindly help me understand why this is not working?
Thank you very much.
Dave
  • That's correct, the router doesn't have an option for you to specify a different port other than port 25.
    As for the firmware, I'm afraid that there will be no firmware updates for this model because this has been discontinued/EOL.
  • Retired_Member's avatar
    Retired_Member
    Check your outgoing server smtp is usually outgoing while mail is incoming but hey I'm just guessing, can't say I ever have seen smtp.mail.???.???
    • dsherry's avatar
      dsherry
      Guide
      https://help.yahoo.com/kb/SLN4724.html
      POP server settings for Yahoo Mail
      POP lets you connect your Yahoo Mail account to a desktop mail client or mobile app. It uses 1-way synching, which downloads your email as a copy into the app, allowing you to move and delete them in the app without affecting the original emails. Here are the settings you'll need to configure your mail client or app.
      Incoming Mail (POP) Server
      • Server - pop.mail.yahoo.com
      • Port - 995
      • Requires SSL - Yes
      Outgoing Mail (SMTP) Server
      • Server - smtp.mail.yahoo.com
      • Port - 465 or 587
      • Requires TLS - Yes (if available)
      • Requires authentication - Yes
      Your login info
      • Email address - Your full email address ([email protected].)
      • Password - Your account's password.
      • ElaineM's avatar
        ElaineM
        NETGEAR Employee Retired
        Is this working before?
        What's the exact model number and version of your device?
