Maril's avatar
Maril
EXT7000 no internet
I have been using the EXT7000 for a year and the past few days I can connect but without internet. I have completed the reset with no luck. Any suggestions what should I look for?
  • plemans's avatar
    What router are you installing it to?
    What firmware is on it?
    When you're installing it, are you using wps or the installation assistant?
    • Maril's avatar
      Maril
      Hello, thank you for your reply. I'm connected to a virgin media hub 3.0 router and I am using the installation assistant.
      • michaelkenward's avatar
        michaelkenward
        What do the LEDs on the device look like?
        Is it wired to the virgin media hub 3.0 router? Or is it a wifi link?
        plemans also asked you about the firmware on your device.
        I assume that you have the EX7000. Visit the support pages:
        Support | NETGEAR
        and feed in the actual model number and check the documentation for your hardware.
        Check the troubleshooting section in the manual.
        You may have done this already, but I can't tell from your message.
        You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
        WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
