Camshaft700
Oct 24, 2021Guide
Failure Connection (Honeywell WIFI Thermostat)
Dear netgear community
Orbi system
Honeywell thermostat wifi
Keep getting error code wrong PWord
Searching the internet I found a bunch of netgear forum post about 2.4g. How the device your setting up the thermostat has to be on the 2.4g network not 5g
I have followed those details and turned off the ssd for the 5g. But when my phone or tablet reconnect they keep connecting to 5g. Looking in the orbi control panel I can confirm that yes They are connected to 5g.
I selected the forget network and rejoined in both devices.
I looked in the orbi control panel and I see no location to temporarily turn off 5g to link the thermostat.
What am I doing wrong ?
Any other method to turn off 5g or force my phone or tablet to join 2.4 only ?
Orbi system
- I can’t edit my first post to add the solution. No special characters can be used (SSID)
So some interesting information
- yesterday thermostat would join iPhone hotspot named “iPhone”
- today thermostat would not join SSId with & symbol in it.
- removed & and the thermostat connects.
I found this information below on the internet.
Honeywell thermostat invalid wifi password
If you’re receiving invalid wi-fi password error when you try to connect to Wi-Fi, please confirm the following:
No special characters have been used in your WiFi network name (SSID) – reset and rename it if necessary.
Some have luck with turning down the 5ghz broadcast strength and then disconnecting/reconnecting.
Have you tried this?
- Thank you
I did so some research and did find someone saying to turn down the 5g to 25% and unplugging any satellite units
Pretty crazy what extent someone has to go to for a internet of things device.
Obviously very poor design and planning on Honeywell’s part.
- RadarsheAspirantYou nailed it!!!! My Nughthawk/Honeywell thermostat connections was lost several weeks ago. Honeywell couldn't help. Netgear also couldn't figure out why my "password(E02 code) was incorrect. Honeywell sent a new thermostat. Ince again Honeywell & Netgear couldn't figure out the issue. I tried in total 3 thermostats(2 new) & two routers(1 new) with the same result. Netgear finally suggested getting a different thermostat because of compatibility problems. I followed the guidance of the original poster & removed any characters that were not a letter or a number. Voilá it worked!!!! Thanks a bunch.
