swharrell
Dec 16, 2016Follower
fishy email
Just received this email...looks fishy. Discussion in July 2016 on this subject was "solved"...is this email legit or not?
Security Vulnerability: VU#582384 | ||
View our Security Advisory page for the latest releases. |
Nothing fishy about it, although that is a natural response. Just Netgear keeping customers informed:
Solved: Two leading Netgear routers are vulnerable to a se... - NETGEAR Communities
There's plenty more where that came from.
Did you follow the links in the email you received?
- Fred__Aspirant
When try downloading the firmware update I get a pop up box that says "all wireless connections will be terminated". Is this a normal request; is it permenent?
Nighthawk AC1900
Thanks in advance.
Downloading from where? Using a hard (wired) connection or a wifi link?
If you are saving the file locally, then when you upload the firmware flash it will close your internet connection and reboot the modem/router. The wifi will come back on then.
