mcse4u's avatar
mcse4u
Follower
Aug 28, 2016
Force 5ghz Channels
I'm having a problem with one iphone 6 which has a damaged wifi.  I would like to try and force the phone to use only the 5ghz frequency if possible to test if just a particular antenna is bad in th...
  • Retired_Member's avatar
    Retired_Member
    Aug 28, 2016
    If you want to connect to 5g only then delete or forget previous connections and then connect to a 5g SSID only. If it is 5g capable it would be obvious in it's setup. One thing is certain it's not a 5gAC
