Orbipro1
Jun 21, 2021Aspirant
Geofencing WiFi 6
Are there any Orbipro, or other WiFi router , gateway that has a geofenced wifi access?
- olympos1625NETGEAR Employee Retired
Hi Orbipro1,
Good day!
Welcome to NETGEAR Community!
You may check the Netgear XR1000 Nighthawk Pro Gaming router.
https://www.netgear.com/home/online-gaming/routers/xr1000/Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
- Orbipro1Aspirant
The router you referred appears to have a feature that is a form of geofencing. The description says the geofence applies to the game server that is joined in a restricted vicinity.
My goal is to I geofence my small office router to restrict access from devices outside the fenced range.
> from devices outside the fenced range.What sort of "fenced range" would that be? Radio in GHz frequencies
is rather naturally range-limited.How would the router know its own location? How would the router know
the location of some other device (especially one to which it has not
established a connection)? How would you specify the boundary?Is there some actual problem which you are trying to solve?
General advice: You might have more success if you described
(clearly) the actual problem which you are trying to solve, rather than
asking how to implement some particular "solution" ("geofenced wifi
access") which might have little or nothing to do with the actual
problem, if it exists at all.
