mic9's avatar
mic9
Help: Netgear WNDR3700v2 firmware
Im having trouble with my router... Its wifi is working but no internet.. My findings, it was loaded with an world wide firmware..
Can anyone help me pin out when can i get a North American firmware for this router..
V1.0.0.12 or higher ..
Thank you
  • Dont mind this..
    I already found the solution..
    The routers 2.4G is damage.. Why? If you connect higher device like laptop with/without password.. This signal goes haywire and sometimes will not emit signal.. But on small devices like phones working fine..
    5G signal is ok..
  • > [...] My findings, it was loaded with an world wide firmware..
       Interesting, but how you reached that conclusion might be more
    interesting.
    > for this router..
       Visit http://netgear.com/support , put in your model number, and look
    for Downloads.  (For older versions, under Firmware and Software
    Downloads, look for "View Previous Versions".)  Find the kit(s).
    Download the kit(s) you want.  Read the "Release Notes" file for
    instructions.
       "V1.0.1.14" seems to be current, "V1.0.1.12" available.  I see
    nothing about different firmware for different regions.
    • mic9's avatar
      mic9
      My router is NA version.. I upgrade its firmware with world wide version..
      I upgrade it, because im having a problem of sudden disconnection of wifi and sometime no internet even if it has..
      Im from V1.0.1.14 NA before i upload the V1.0.1.12 WW
      Im not expert on this, i just update the firmware to fix the problem.. But its not doing good, the problem gets worst. Now the wifi is not giving internet..
      I already go to downloads section and look on previous version.. Theres no North American version
      • mic9's avatar
        mic9
        Dont mind this..
        5G signal is ok..
