dorismc
Feb 09, 2024Aspirant
Help with setup older router as acess point/extender
I am trying to set up a Netgear N600 wireless dual band router WND3400 as an acess point or extended wireless.
I want to put this router out in the RV which is close t my wireless cameras. I know how to access the router and have an ethernet cable connected to a seperate laptop not connected to the internet.
I have read and see on youtube and doc but this router doesn't have what netgear doc say to bridge.
The docs say click avanced/advanced setup/wireless bridge...there i no wireless bridge in the router menu.
Does anyone know/have step by step insructions on how to get this to work?
I did set up a different ssid and password for this router..and I think to uncheck DHCP and don't know what to do after this and how this router connects to the camera that are using my main computer router's SSID and password.
Problem with this is that if the laptop doesn't get a signal in the RV, neither will the router. RVs are big faraday cages in that they're made from metal. Which does a great job of blocking wifi.
If you look at most rv's, they have some type of external antenna setup to get a connection into the RV. Whether its a cellular connection or a router with some type of internal/external broadcast ability.
- dorismcAspirant
I had an almond securifi https://www.securifi.com/rg/softwareupdate-almondplus that worked perfectly. The menu on that device got messed up and I can't click on letters or numbers to connect it again. That is why I know the older router with the right setup would work. The wireless of the netgear will reach my Zytel wireless modem in the house..
You can always look at some other posts about it. Thats an very old router. I haven't messed with one in years.
You might be better off picking up a half decent wireless extender that is designed for the purpose you're looking for
I'm guessing that this is the WNDR3400, which comes in three versions between 2010 and 2014.
I see no indication that your ancient router supports access point mode.
It may work as a "wireless bridge", but that depends on connecting to a router that supports that mode. Few do.
Does anyone know/have step by step insructions on how to get this to work?Read the manual for your device.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Wireless Repeating (Also Called WDS).
