godsbman's avatar
godsbman
horrible Netgear genie and parental controls
Ok,  I just bought this N750 to upgrade my N600 today cause I couldn't get the inborn parental controls in the N600 to operate.  apparently it is a toss of a coint if it works on the N600.  So I bought the N750 and started to set it up.  This something horrible happened.  It installed this malicious application called Genie.  I've went through the steps to set it up.  everytime I try to set up parental blocks It tries to have me register the unit.  This it takes me to OPEN DNS.... WTH  why cannot this thing just have inborn settings.   It seems I cannot set up the router without the genie.  Can someone tell me a work around or at least a model of router that doesn't utilize the horrible Genie application?
Thanks
  • Yes you remove Genie and log in the router by a browser by loging into 192.168.1.1
  • Genie is Netgear's network management software...do you have something against it? why did you refer to it as a malicious software? did it do something horrible to your network?
    to use parental control with Netgear hardware you need to set up an opendns account....i dont know the technical reason behind that but that's how it is with Netgear hardware
    without netgear genie installed on your pc or laptop, you can't run parental control even after setting up the opendns account
  • I call it malicious because it was taking over my control of setting up my network. So possibly supper annoying us a better term to may down right painful to use. I actually was able to utilize the ip address and directly set up the network that way and parental controls do seem to be working without genie or open dns installed.
    Utilizing open dns was also horrible because it kept flaking out, I would type in an address and it would stop adding terms after a list of two.
    I have used netgear for years because they used to be straight forward and easy to set up even if you weren't a networking genius and without the need for a separate running application. But that seems to have changed. I will be doing a larger network update later this year and it looks like I may have to start researching for new equipment that doesn't have the need for a separate app
    • William10a's avatar
      William10a
      Master
      Genie is not needed to setup a netgear you have to go back the browser log in. I like the old way whether a software program anyways because no matter who's router and install and setup program there will always be a problem. Netgear is not only company that runs in problems with their coding in the programs that they use.
    • StephenB's avatar
      godsbman wrote:
      I call it malicious because it was taking over my control of setting up my network...
      I'm sure lots of people would call that helpful :smileyhappy:
      I prefer to set things up myself, and as William10a points out you don't need to use Genie.
      I don't use parental controls myself, but I do know that the built-in controls only work with http, not with https.  Which makes them basically useless (my opinion, not Netgear's).
