Troyg66
Jan 30, 2017Aspirant
How can i recover my user log in so I can reset password? I have an N600 WNDR3400.
I am trying to reset password, but I cant rememner my user ID to log into system to reset password. I also tried to do a factory reset, but after doing so, my original password still works. I still c...
- Feb 01, 2017
I am trying to reset password, but I cant rememner my user ID to log into system to reset password. I also tried to do a factory reset, but after doing so, my original password still works. I still cant log in with User ID:admin Password: password.
Do you have a wireless computer say with windows 7 or higher on it and stills access the Internet ?
If so and you used the same ssid and pass phrase on the computer as the router's user name and password your in luck.
You can access the wifi account selection in widows security and find the account for the computer to connect to the router under password your find a sting of stars click the box that says show hidden characters it will show you your password .
An easy way of accessing an router when people forget their information and want another device when they want to keep it simple.
Troyg66
Feb 01, 2017Aspirant
Thank you, I have more than one reply using this. I think this will work, thank you
