caroledickson13's avatar
May 09, 2022
How do I change my password?
I think we have been hacked. Using more data than we possibly could. Can someone tell me how to change my password?
I have looked everywhere.
Thanks.
    • caroledickson13's avatar
      caroledickson13
      Hi, thanks, I'm trying to change the network key password that was assigned from the factory. When I go to that website you posted it won't let me sign in. Says its not secure. My router is R6220.
      Thank you so much for your help.
      • FURRYe38's avatar
        Wire connect a PC to the router and factory reset the router using the back push pin button. Hold it in for 10 seconds then let go. Then log in to 192.168.1.1 or routerlogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on. Then go in and configure the SSID name and give a new PW here.
