JohnnyChristo
Dec 10, 2020Tutor
How do i connect to hotel portal to bridge a N600
Hi thanks for reading
I live in an appartment block. It has a portal login.
I wish to configure my router so it logs into the portal and shares the wirless to my various items like my PC home google and my chromecast.
I need a step by step guide as i am not very expert.
Thanks in advance
JC
You need a router that supports wisp mode.
https://wifi-settings.com/wireless-routers/wisp-mode/
That route doesn't support wisp mode.
Netgear made one years ago but its out of date.
I'd recommend looking for travel routers or even just searching for a router with wisp mode
- Hi appreciate your reply
I’m considering putting openwrt on it with the travelmate pkg
What’s your thoughts?
JC- plemansGuru - Experienced User
I've only used ddwrt on a r7000 and that was a long time ago. so I'm not a good reference for that. You'd have to check the ddwrt forums.
