Jellicoe
Feb 03, 2015Tutor
How to add a mac address access control
I am a bit confused here. I see that there is the access control page, but I can not figure out how to add a new iPad?
Rachael
- JellicoeTutorFrom what I have gathered from the forums, the access control function has been disabled on the WNDR4500.
But we will see what happens when the new ipad arrives on the 4th.
Thanks Andy - Babylon5NETGEAR Employee RetiredI’m at work at the moment, and don’t have access to the ‘4500 manual to check, but I suggest that you temporarily disable the Wireless Access List, let the iPad connect, then enable the list and select the iPad as a trusted device.
