ducari3's avatar
ducari3
How to connect a wrt150n and a wndr3400v2 together to expand wireless connection
How to connect those two routers together wirelessly but with the first as main router without losing my security and port forwarding setting?
Thank you by advance for your help!
  • Thank you for help. The wndr3400v2 is enough for my home. So, problem solved.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hi ducari3
    Welcome to the community!
    First, verify if your WRT150 is capable of WDS (Wireless Distribution System). If it does, check page 81 from the manual.
    • ducari3's avatar
      ducari3
      • ElaineM's avatar
        ElaineM
        You're very welcome.
        Have a great day!
