Misa23
Oct 15, 2023Aspirant
How to connect my R6300 using my mobile device as hotspot?
Dear all
I am wondering how I connect my (old but excellent) R6300 Netgear using my iPhone as a hotspot:
My iPhone hotspot ---> connecting to Netgear R6300 (instead the usual lan cables)
Is this possible with the R6300? And if yes, how...?
...Or do I need another Netgear Modem?
Thanks a lot
Misa23
If the router has a wires bridge mode, then you could connect it to your phone wifi hot spot signal as a wireless client then you could use the LAN ports in back for wired devices. If the router doesn't then no, the router you have won't work.
- microchip8MasterNope
- Misa23Aspirant
Hi microchip8
Thanks for your input.
Guess nope means this is not possible and I need to buy another product / router?
Have a nice Sunday
Misa23
- Misa23Aspirant
Thanks a lot for your input!
