alvinak
Jan 17, 2016Aspirant
how to set up a guest user - model r6300
Hello I need some help on setting up a guest user on my router. I would greatly appreciate your help! :) (I had just posted a new discussion on this, but I'm not sure if it went through so I'm post...
- Jan 17, 2016I would use 2.4 GHz for your guest network. It's supported by all devices. Use WPA2-AES. It's the most secure encryption method. The guest network by default will only have Internet access. There is a setting to change it, but don't touch it.
TheEther
Jan 17, 2016Guru
- alvinakJan 18, 2016AspirantThank you!!! So do I just leave the default checked box alone and not check any other boxes?Does it give you the option to make a password for the guest user? and in the future, can I diable and enable the guest user?Thanks so much again!! So helpful :)Alvina
