Face_De_Ace
Apr 13, 2016Star
How to set wifi device data cap quota R6400
Hi All, My first post here, and my first NetGear device, so forgive me if this is known by all except me. I would like to know how to set a monthly total data (Mb, Gb) quota for each device on ...
- Apr 16, 2016You can post a request on the Idea Exchange forum.
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
TheEther
Apr 14, 2016Guru
You cannot set a per-device data cap. You can set a total data cap under ADVANCED > Advanced Setup > Traffic Meter.
Face_De_Ace
Apr 14, 2016Star
Yes, I see under the advanced settings for the R6400 there is a traffic meter. You can set the monthly total throughput limit and what you want the router to do when the limit is reached. For example, disconnect from the internet.
I was hoping there is or could be developed an expanded features version of this traffic meter. One that allows you to set a monthly total throughput limit for each MAC or each manually assigned IP. In otherwords, the same thing that is there now, but able to break it down more granular to each IP/MAC address.
Maybe this could be developed and rolled out in a new firmware update?
