njfiddler's avatar
njfiddler
how to setup WNDR3800 router as a bridge
I have a FIOS router, with an RJ-45 cable/jack to the room where I want to create a new wifi network for that part of the house. I got it to work, but the crucial step seemed to be when the Netgear changed its IP to 10.0.0.1. I had full internet access....then I had to move some furniture, which meant the router briefly lost power. Now, I have the wifi network, but no internet connectivity (although the Internet light is green, and the router config page says Good for Internet). What is the reliable way to configure the NDR3800 into this sort of bridge mode?
  • Hi @njfiddler,
    If that is the case, then you can setup the router in Wireless AP mode. You can do that by accessing the router's UI and go to Advanced > Advanced Setup > Wireless AP > Enable Access Point Mode > Apply. This will allow the NETGEAR router to be in the same network as the FIOS router and at the same time broadcasting a separate Wi-Fi for your devices to connect to.
    Dexter
    Community Team
  • I would like a separate Wi-Fi from the Fios one, that tends to be maxed out with gaming, etc.
    I didn't try the wizard, do I needed to run that on a laptop connected to the netgear?
    I haven't tried that, I assume you mean more than power cycle.
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi njfiddler,
      I would recommend connecting a computer to the NETGEAR router then running the setup wizard and select the option to set it up as a router and not as an access point.
      Dexter
      Community Team
      • njfiddler's avatar
        njfiddler
        It's weird, but I came home from work today to find it working just fine. I didn't get around to doing anything to the router!
        I will run the setup wizard if it breaks again. I don't understand your instruction to configure as "router." Isn't access point what I am looking for?
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi njfiddler,
    1. Do you prefer setting up the WNDR3800 as a separate router or as an access point?
    2. Have you tried running the setup wizard again?
    3. Have you tried resetting the rouer?
    Dexter
    Community Team
