milqueto's avatar
milqueto
I deleted the default Available Network Folders
If this has been covered, I can't find it, so apologies. But, I have deleted my default Available Network Folders, and I don't know how to restore it. I have hit the master reset, but it's still gone. Can someone please point me in the right direction to restore it? Many thanks.
  • Well, I thought I did.
    I did another hard reset. Redid all my settings, which I had saved, re-inserted the USB, and it's now on the network. I don't know what it was. But all is right with the network now. Thank you for all the help.
  • Are you talking about configuration file? What is default network folder?
    • milqueto's avatar
      milqueto
      Yes, the configuraton file. Here is what I have:
      It should look like this (captured from the online manual):
      How can I restore the default one?
      • VE6CGX's avatar
        VE6CGX
        Master
        How did you save config. file. Manually by yourself or...?
