jesusyogie
Jan 20, 2016Aspirant
I have a netgear Wndr3700 and everything is fine except 4 laptop.How can I bridge netgear R6300V2?
Hi @jesusyogie,
1. Are you looking to setup a separate network using the R6300v2 or set it up as an access point within the same network?
2. Setting it up as a bridge will require a different set of steps as well. You may refer to the link below for the user manual and the steps are found on page 102.
http://www.downloads.netgear.com/files/GDC/R6300V2/R6300v2_UM_20May2015.pdf
3. The credentials that it is asking for are for the router admin page. By default the username is 'admin' and the password is 'password'.
Dexter
Community Team
- Retired_Member
Which part of the manual are you having trouble with?
- jesusyogieAspirant
What website do I go to in order to hook up the R6300V2 router as abridge router to the WNDR3700 router?
I used www.routerlogin.net and that website was looking for a network name and password. Do I input the new network and password that came with the R6300V2?
