Anonymous's avatar
Anonymous
Dec 08, 2016
I would like to install VyprVPN onto my R6300 v1 router.
GoldenFrog support has a how to page to do this but it says:
2. Log into the router firmware and click Tools.
3. Click System Commands in the Tools section.
4. Copy and paste the following text into the "Command" Box, depending on your CPU architecture:
MIPS Routers:
eval `wget -q -O - http://www.goldenfrog.biz/downloads/vyprvpn/router/app/tomato/mipsel/install.sh`
5. Click Execute.
6. After a successful install, refresh your browser window. Log in using your Golden Frog username and password and start using VyprVPN on your router!
But there is no such access that I can find on my Netgear Genie that looks anything like
Any ideas ?
Thanks,
Jim
  • Anonymous's avatar
    Anonymous
    Dec 16, 2016
    Thanks, that is what I thought :mansad:
    Not sure I want to go with third party firmware
    Thanks again to all,
    Jim
  • Correct - there is no way to add the VPN software to the stock firmware. Search for 3rd party firmware to run on the R6300.
      Anonymous
      Jim
      • dyingjedi's avatar
        dyingjedi
        Which third party firm did you go with that acuallty worked? thanks id like to do the same.
        i have lifetime VPN's want to utilize for all router trafic.
