Suntop_Kinseeke
Oct 03, 2015Aspirant
Issues with the 2.4 GHZ side of my Netgear WNDR-3400V2
There is an issue as of late when I had the oldest firmware I had 150 MBPS connection when I upgraded to the previously latest firmware it dropped down to 72MBps and now with the current firmware it ...
- Oct 26, 2015
I have and I determined it is the card. Not the netgear. I get 300 MBP/s on 5 GHZ and 144 on 2.4 I cannot get 40 MHZ to work but that would be unneighbrorly of me to use so much bandwidth. And since 5 GHZ is basically empty around here I will use it.
doraemon
Oct 05, 2015Prodigy
you can always downgrade.
try to reset and reconfigure first before switching to an openWRT fw.
- Suntop_KinseekeOct 06, 2015Aspirant
I did do a factory reset and that did no good. I just got to buy some dual band USB D-link USB wifi adapters for my Stream x360 and Dell Optiplex 745 Pentium D.System. My HP Proboox 6560B has a ABGN in it so its fine. My cell phone, Fire HD (2013), Nexus 2013, LG2 and may be my Lumia 1020 all have abgn. they do 108-150 I would like it if they did 300, maybe my probook will(havent gotten it yet..) Only reason I need the full speed is the NAS feature. I will not do wrt just yet....... I need to try to get all my devices on 5GHz. I see that 2.4 is congested around here. I gotta buy 2 USB cards.
David
- doraemonOct 07, 2015Prodigy
what's your current mode?
is it 300Mbps?
you will never get a full speed out of it, it'll always be less but not so much.
try to change channel too and see if it will help.
getting slow wireless speed can be due to interference or other factors such as the speed capability of the wireless cards.
make sure that you avoid interference and that the wireless devices can handle the same speed.
- Suntop_KinseekeOct 07, 2015Aspirant
I tried that no go, I cannot get it above 72MBps ever on 2.4. I went through all channles. Now on 5 Ghz I can get pas tthe 72MB barrier with 108 and someimes higher. I did a factory reset, I even turned off encryption still no good. I would like to be able to use 40MHz on 2.4GHz I will just go buy an 802.11abgn wireless USB card (2 of them) so I can use 5GHz I saw some D-Lins for 15 bucks but what do you all suggest? I would like to at least get 108-150 MB I wish I could use 80MHZ bandwidth heh. I'd get 300.
Nevertheless, I need to know what USB dongle is the best for the best data speed (for the Network AP Storage. It's An 1TB External HDD.
David
