Suntop_Kinseeke
Oct 03, 2015Aspirant
Issues with the 2.4 GHZ side of my Netgear WNDR-3400V2
There is an issue as of late when I had the oldest firmware I had 150 MBPS connection when I upgraded to the previously latest firmware it dropped down to 72MBps and now with the current firmware it ...
- Oct 26, 2015
I have and I determined it is the card. Not the netgear. I get 300 MBP/s on 5 GHZ and 144 on 2.4 I cannot get 40 MHZ to work but that would be unneighbrorly of me to use so much bandwidth. And since 5 GHZ is basically empty around here I will use it.
ElaineM
Oct 21, 2015NETGEAR Employee Retired
Have you tried connecting just this pc alone and no other wireless devices connecting to 2.4Ghz signal?
Also, make sure that when you connect, channel width is set to Auto then change the channel to a unique one.
Suntop_Kinseeke
Oct 26, 2015Aspirant
