fyodorkaramazov's avatar
Nov 01, 2016
Large house—want to use two R6400 routers with single SSID
Hi,
I own two R6400 routers. Currently, secondary router is connected to primary via Ethernet cable, and I have two SSIDs broadcast from opposite ends of my large home.
I'd prefer to use 1 SSID.
Trouble is, I can't seem to login to the secondary router to set it up in the manner this article recommends <http://smallbusiness.chron.com/setting-up-wireless-routers-same-ssid-68675.html>.
Please offer solutions to this problem.
Additionally, I'd prefer to have seamless network transfer while I walk around my home. Will that happen automatically after both routers are running same SSID? Or will I have to tinker with channels?
Thank you.
    • netwrks's avatar
      netwrks
      Master
      You will most likely have to play with AP (or router) position. There should be a slight wireless overlap between router and Access Point, so that a handoff can actually occur. Mostly, wireless clients are the issue, as some clients stick (hang on) to a wireless signal, until it fades to nothing. Don't expect miracles with consumer grade networking hardware.
      • Retired_Member's avatar
        Retired_Member
        Apple products are the worst regarding roaming!
    • fyodorkaramazov's avatar
      fyodorkaramazov
      Somewhere within the rabit hole of trying to find an answer to this problem, I thought I came across the fact that switching my secondary router to an AP would require me to turn off the primary router's WiFi capability; however, your instructions proved otherwise. Thank you!
