Fhaye's avatar
Fhaye
latest firmware 1.1.2.14 for my wnr2000v3 is BUGGY when in French language !!!
Hi,
I just updated my router wnr2000v3 to the latest firmware. Bad idea !
It starts changing language interface to french, and then... I cannot access to advanced menu: the tab "avancé" does not respond to my clicks !!!
Can someone help to sort this out, please ?
  • OK, I found the solution by myself.
    Forget the tftp stuff...
    You just need to type in the browser the following URL, when connected via wired connection: http://192.168.1.1/adv_index.htm
    That's it!
    But remains the issue of the tab adv. which is not clickable, which drove me to this question on this board...
    You might now close this discussion...
    Thx anyway.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Welcome to the community, Fhaye
    Did you try to reset the unit after updating the firmware?
    If not, I suggest that you factory reset the unit then reconfigure the router as if it's brand new out of the box.
    • Fhaye's avatar
      Fhaye
      Hi,
      of course I did that...  But ufortunately, the router boots up and same thing happens : no way to get the "advanced" ("avancé" in French) button,
      This is due to this version of the firmware.
      You might reproduce same behaviour by using a Windows PC running Windows 10 in French language.
      It looks like the interface language, when in French especially, cannot allow this "advanced" button to be "clickable"...
      Thanks for advice.
      BR,
      F
      • ElaineM's avatar
        ElaineM
        If you downgrade to the previous version will you experience the same problem?
