cm2297
Sep 21, 2015Aspirant
Live parental controls fails to setup
I have a N900 wndr4500v2. When trying to set up the parental live controls I make it as far as putting in user name and a password. I hit enter and it comes back with the password not being long enough. I have tried different user names and passwords and it won't go any further than that.
Can you verify if using a special character and capital letter for password will help you guys pass this registration?
Looking forward to your responses.
- ElaineMNETGEAR Employee Retired
Hello cm2297,
Welcome to the community!Is this for the bypass account or just simply creating the login for the Parental Control?
Can you post a screen grab of this window?
Did you try using a different web browser? Also, try deleting browsing history and clearing cache.
Looking forward to your response.
I have this exact same problem on a 7500 AC Nighthawk router. I get to the place in Genie where I try to setup a new OpenDNS account and it gives me an error that the password needs to be between 6-20 characters. But no matter what password I try to use it keeps giving me that error. I need these parental controls.
- cm2297Aspirant
This is for the parental control.
I am trying to create this from the Netgear app that was downloaded to my pc. I am not opening a browser seperate from the app.
- VaqueroAspirantWhen I tried to use this feature on my iPad, i get the message that my username must start with a letter or number. The username I tried to use starts with R. What gives?
Thx - nortbrooknzAspirant
Hi Moderator,
Having trouble logging in to LPC through genie....opendns account, says that I may not be connected to the internet... which is not the case.
I have the latest firmware update installed.
Modem model is DGND3700v2
Any suggestions?
Vaquero Our engineers are working on this and we will soon release a fix for it.
nortbrooknz Do you have the latest Genie App installed? Try to uninstall and reinstall the app.
By the way, are you using the Genie on a computer or an iOS/Android device?
Did you try using a different computer or device?
Let us know what happens.
I have 2.4.16.00 on my Desktop which I will uninstall today.
On my i-pad I have 2.4.18... I may try it on the i-phone to see if there is any difference there.
Will load new genie version on my Asus Laptop and see if that works.
Brent
