Mulkinsa95's avatar
Mulkinsa95
Location issues after moving (R6400v2)
I've recently moved from Oklahoma to Pennsylvania, and I've brought along the router I bought several years ago. Upon connecting it to my parent's modem, it helped a lot with net issues we were having (after my mom insisted that their modem was actually a router), but both of my parents are experiencing the same issue, while I am not. Every time they try to use location services (Google, websites, online ordering, etc), it keeps suggesting the area that I used to live in. But for me, it always pinpoints exactly where we currently live, and easily finds the same things my parents are struggling to find in our current area.
From what I've read online, I keep finding suggestions about opening Google maps repeatedly? Or going into Google maps and setting our current address as their home, which I'm unsure if they've done yet or are willing to do. When I moved, I set our current address in Google maps. Additionally, my mom hikes a lot in the mountains / off trails, so she uses GPS tracking on a daily basis so we can see where she is.
I've also read some articles / forums that said changing the IP would help, but I'm personally not very tech savvy, so I didn't want to go in half blind before asking about it and accidentally mess something up.
Lastly, in case it's important, my parents only have their phones, and I use a phone, tablet, and PC. All of my devices locate correctly in PA, where my parent's phones locate incorrectly in OK.
  • plemans's avatar
    what modem/gateway is it connected to?
    Did you ever factory reset the router and do a new install process on it when you moved it?
    • Mulkinsa95's avatar
      Mulkinsa95
      The modem is an Arris Touchstone CM8200. I'm unsure about the gateway. Since this device is on my parent's account, so I'd have to ask them for access to it.
      For the reset and install, I did not, as I didn't realize that was something that had to be done! I simply plugged it in, updated the firmware, and we started using it.
      • plemans's avatar
        It doesn't have to be done but is usually recommended when moving from one service to the next.
        I'd try that first.
