Warren57's avatar
Warren57
Metal building wifi
Another remote metal building question.
i live on an acreage. Added a wavlink extender to my network at the house. Works good everywhere across the acreage, good signal, except wifi signal inside metal building is bad. Great outside the building but can’t get through the steel.
so I have an older netgear ac1600 extender that I decided I would put inside the metal shop building. It gets some signal but not great. So I realize the antennas can only pick up signal that’s in the building.
my question, can I take the antennas off and mount them outside and connect with cables? We are talking 1’ or less. NETGEAR extender on inside wall and antennas on outside. That way I would get the good wifi signal from outside and send it through the building.
if this makes sense what cable, fittings, etc would I need?
or is there a simpler way to accomplish my goal?
thanks
warren
