Warren57
Feb 13, 2026Aspirant
Metal building wifi
Another remote metal building question.
i live on an acreage. Added a wavlink extender to my network at the house. Works good everywhere across the acreage, good signal, except wifi signal inside metal building is bad. Great outside the building but can’t get through the steel.
so I have an older netgear ac1600 extender that I decided I would put inside the metal shop building. It gets some signal but not great. So I realize the antennas can only pick up signal that’s in the building.
my question, can I take the antennas off and mount them outside and connect with cables? We are talking 1’ or less. NETGEAR extender on inside wall and antennas on outside. That way I would get the good wifi signal from outside and send it through the building.
if this makes sense what cable, fittings, etc would I need?
or is there a simpler way to accomplish my goal?
thanks
warren
another image:
another
An extender by its very nature cuts throughput by 50% because it uses the same chip to go router---->extender and then extender----devices. And it can't do both at once. Plus you have to factor in distance/obstruction. Because of those its usually 30-45% that most people see for speed. So you won't see that 900+ speed out of any extender setup. The router that CrimpOn posted will be your best bet and provide a solid connection. maybe not as good as a point to point system but it should be "good enough". Good enough means that streaming 4k only takes 25-50mbps. You should hit that without issue with what your plan is.
- Warren57Aspirant
Well that was a failed experiment. Got everything connected and the signal got worse! But it was worth trying.
guess I will be trying to figure out a Ethernet cable from the house out there this spring.
What device did you end up getting?
And you placed it outdoors?What speed did you get connected directly to the outdoor AP?
And then you ran an ethernet wire indoors to the Netgear AP?
Did you re-run the install on the Netgear ex6200 to place it in access point mode? (or it'll still be running as an extender)
- Warren57Aspirant
Just an update after resetting and reloading every piece at lest 6 times, adjusting settings, etc. I finally got it all working. Have the house wifi network, the wavlink AC3000 access point getting signal across the acreage, the wavlink AC600 as an access point at the metal building, with an Ethernet cable going to the netgear EX6200.
have a pretty good signal in the building now .
thanks for everyone’s thoughts.
